May 19, 2017, 15:07 |
Residual remains constant- Steady state
Suraj Pawar
Rep Power: 9 |
I am trying to model ducted Ka 4 70 Propeller in open water. Instead of modeling the whole propeller I am modeling only quarter domain with one blade and quarter of the nozzle. I am using below physical model:
Constant density Steady State SST K-w turbulence model Gamma transitional model I am using velocity inlet and pressure outlet boundary condition. Also I am using periodic rotational boundary condition for two sides of the domain. I have two domain rotating and stationary. Rotating domain is surrounding only propeller and stationary domain is outside rotating domain. And I am applying moving reference frame for rotating domain and stationary domain has lab reference frame. I also created the internal interface at the contact surface. I am having some trouble with the convergence of residuals to very small value. After few iterations all residuals remains almost constant. My velocity component has converged up to 10-4, Continuity up to 10-3 and k-e up to 10-2. I think K-e residuals attain constant value and after that rest of the residual are attaining constant value. So how can I get k-e residual to get converged to smaller value? I changed the turbulent intensity at inlet and outlet to 0.001. Also, my thrust of the propeller, duct and propeller torque becomes constant once the residuals attain constant value. Thanking you. |
May 19, 2017, 19:26 |
Rep Power: 24 |
With your current physics and mesh resolution, that's the amount of error you can reduce. If you want to change it you will have to change the mesh or resolve the physics better.
May 19, 2017, 19:41 |
Suraj Pawar
Rep Power: 9 |
I tried using Transitional Gamma model also for capturing the transitional effects. But the same thing happened and residuals converged only up to 10-3 to 10-5. Can you recommend some changes I should make to make my residuals converged to lower value?
I am thinking of using unsteady analysis with sliding mesh but I think for this I would have to model full domain and not just quarter domain. thank you. |
May 19, 2017, 22:01 |
Rep Power: 24 |
Honestly I think the quarter domain and steady-state are the two biggest problems. Those are pretty poor assumptions for a flow and geometry like this. Steady state with the full domain would be better.
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
