May 11, 2017, 22:01 |
Extracting volume from surface CAD mesh
Val Jewtoukoff
Rep Power: 9 |
Hi everybody,
I will start by saying that I am a newbie, so please be indulgent. My goal is to have a domain in which I have a city block composed of several isolated houses. I am importing a CAD surface mesh (in stl format) as a part in Star-CCM+. Then, I repair this mesh until no problem is found. After this, I want to extract a volume from that surface mesh and subtract it from the domain. The problem is that I get an error message when extracting the volume: "Could not find appropriate topological region from input parts" I have no idea how to fix that problem, and yes I searched for solutions before on Google but didn't find anything that helped. I'd like to add also that as suggested on some pages I found online, I also tried splitting by surface topology, then apply extract volume to all the parts but it doesn't work. Help and explanations are more than welcome! Thank you! Last edited by vjewtou; May 12, 2017 at 00:14. |
May 12, 2017, 10:51 |
Rep Power: 25 |
If you repaired the domain why do you need to extract the volume? It's closed, just mesh it as is.
May 13, 2017, 15:14 |
Val Jewtoukoff
Rep Power: 9 |
Thank you. It solved my problem.
I just assumed that I needed to extract a volume from the surface mesh, but this wasn't the case here. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ICEM] Extracting Surface from Volume mesh | Joh | ANSYS Meshing & Geometry | 1 | April 20, 2016 18:10 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[ANSYS Meshing] orientable surface mesh - CAD error | powpawell | ANSYS Meshing & Geometry | 0 | April 1, 2015 02:15 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
