Hot spots appearing in volume mesh
Old   May 9, 2017, 22:25
Default Hot spots appearing in volume mesh
starccmuser is on a distinguished road
I am running a simple cylindrical geometry with a high pressure region at the start of the simulation. Part way through the simulation, when the pressure wave has passed through an area of tube (which remains at a relatively steady pressure afterwards) spots of high pressure appear on the tube (see link below). I am using a volume extruded mesh which makes me think it isn't a meshing problem. Any ideas?
https://gyazo.com/9563716eea5b38ae64087523c474b2c1
starccmuser is offline   Reply With Quote
Old   May 25, 2017, 17:12
Wade
wadeellis is on a distinguished road
I have seen something like that but with temperature before. It may mean that the simulation hasn't converged all the way. So, you might try letting it run for a little while more to see if the pressure comes down. Otherwise, you might change the models you are using.
wadeellis is offline   Reply With Quote
Old   May 25, 2017, 20:45
Needed a lower time constant, problem resolved
hotspots, shock tube, turbulence
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
