May 1, 2017, 15:43 |
Varying Injection point
Vijay Ravisankar
I am trying to vary the injection point after every iteration such that the streamline flow I am creating has a flow continuously and does not start from a fixed injection point after every iteration. Is there any way to set the injection point after every iteration is the end point of streamline at end of iteration. Thank you so much. |
May 5, 2017, 01:47 |
Nils
Rep Power: 10 |
so do you talk about lagrangian particles or DEM? Or do you just wann streamlines? There's an option under derived parts.
If you wanna change the injectionpoint of a lagrangian injector, you have to do it manually or write a macro in Java. |
May 5, 2017, 11:32 |
Vijay Ravisankar
Hey. Thank you so much for your response. I am trying to inject a tracer particle at the inlet and check the flow pattern of the particle. Since my particle is pretty small, I expect them to follow the streamline, so tracking the streamline should be fine as well I changed the length of the streamline and I believe I'm getting what I want, although I am not really sure though.
injection point, star ccm+ |
UDF for particle injection using file | shahjehan | Fluent UDF and Scheme Programming | 2 | June 28, 2020 10:44 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 03:44 |
