April 21, 2017, 06:46 |
Mesh morphed error in CCM+
Rep Power: 15 |
Hey guys. I am trying to do an ice accretion analysis in star ccm+. To do this you have to use mesh morphing. I have an issue that when I do this on a simple wing it works fine. However any other portion of an aircraft, I find that the wall distorts and compresses the first prism layer only. The rest of the volume mesh won't move. Then I get a negative cell. Anyone else see this or know how to get around it?
April 21, 2017, 19:50 |
Rep Power: 24 |
How thick is the first layer height? If it's very small you might find you need to reduce the morpher tolerance.
April 23, 2017, 15:50 |
Tolerance
Rep Power: 15 |
The first prism layer is pretty thin. I've done my best to make it so that the aspect ratio isn't too high by refining but that doesn't seem to change anything.
I'll try and drop the tolerance to 1e-10 from 1e-7. I'll report back tomorrow. Oddly enough I have had this work numerous times on. 2d wing numerous times with pretty large deformations. However with this more 3D shape the morphing seems to struggle. Thanks for the idea. Any and all ideas welcome. |
April 24, 2017, 06:27 |
Rep Power: 15 |
Well I gave this a shot but it did not work. Same issue occurred. The first prism layer collapses while some but not much movement from the volume mesh is observed.
Any other thoughts? |
April 24, 2017, 11:28 |
Rep Power: 24 |
Maybe try giving a high-reynolds mesh a shot?
April 24, 2017, 14:33 |
Rep Power: 15 |
I like the idea! First question about that, what is a higher Reynolds mesh?
April 24, 2017, 17:52 |
Rep Power: 24 |
Well if you have very small first cell heights I'm assuming you're using a low-reynolds wall treatment (no wall function). So if you switch to using wall function this relaxes your first cell height requirement.
April 25, 2017, 06:22 |
Rep Power: 15 |
Ahh okay I understand what you're saying. Thanks for clarifying. In past studies with more 2d shapes I've found that ice accumulation is very sensitive to y+. Therefore I wouldn't be able to get away with thicker prisms.
I just tried using a poly mesh as well as a trim. Don't not change. Still failed. Starting to think ccm morphed just isn't robust enough. Have any other thoughts? Thanks for ideas thus far. |
morphing, negative cell volume, star ccm+ |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
