Simulating particles concentration reduction by vegetation |
April 21, 2017, 00:41 |
I had done velocity simulation using star CCM+ before.
Right now, I am trying to simulate the vehicular pollution reduction potential by trees and shrubs at roadside conditions. Anyone has experience doing this before? - how do you simulate the porosity of the vegetation? - how to set up the particulate pollution in CCM? Thanks a lot. |
April 23, 2017, 17:42 |
Nestor Rueda
Rep Power: 10 |
Do you have to explicitly model the vegetation?
The common practice is to define a surface roughness. Have a look at this: http://www-das.uwyo.edu/~geerts/cwx/...roughness.html As for the emissions from the cars, I would not model explicitly the particles but a concentration instead since the particles must be smaller than PM10. If you want to use particles anyway, you have to use a lagrangian multiphase model and define the injection points. I would define the vegetation as an escape condition so the code deactivates the particle after touching that boundary. Hope it helps, Néstor |
pollution;vegetation |
How to calculate the particles concentration? | chpjz0391 | OpenFOAM | 7 | August 8, 2021 09:27 |
How to use "function" under contorlDic to calculate particles concentration (kg/m3) | chpjz0391 | OpenFOAM | 1 | May 24, 2016 10:03 |
Velocity from varying particle's concentration | nombood | Fluent Multiphase | 2 | April 25, 2014 10:32 |
Is it necessary simulating Windbox gas fluidization without particles by Fluent? | Mr.choi | FLUENT | 0 | August 8, 2012 22:43 |
concentration of particles | scarecrow | FLUENT | 3 | August 19, 2010 05:02 |
