creating interface between solid and fluid domain |
Mustafa
Rep Power: 9 ![]() |
hi
my problem is so simple i cant create interface between two different domain to transfer heat. https://ibb.co/me2hqk https://ibb.co/kF6Wi5 https://ibb.co/cnOYwQ can i create interface just selecting both region and click create interface? i tried but it did not work. |
Rep Power: 25 ![]() |
Look in the user guide, this is covered quite a bit there. You need to create interfaces between the boundaries. Ideally your interfaces should be created automatically with proper imprinting done at the parts level.
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
