Phase Change in VOF Evaporation/Condensation Models |
April 12, 2017, 20:51 |
Ramon Yoshiura
I am currently working on a project that condenses steam in a closed vessel using Star CCM+ 9.04.001-R8 and having problems with phase change. The physical models chosen are implicit unsteady, Eulerian Multiphase VOF, turbulent, Multiphase Interaction, gravity, segregated fluid temperature, and Evaporation/Condensation options selected. The continuum is fluid with two Eulerian phases; steam and water. The material properties have been modified to match pressure and temperature conditions. The problem is set up to have the vessel initially filled by steam at 400 K with pressure at 14.7 psi and surrounded by walls at 300 K. The issue is that even though the temperature of the fluid is shifting from 400 K to 300 K as each time step is satisfied, phase change does not occur. If the pressure is 14.7 psi, the saturation pressure should be 373 K and phase should be occurring at this point. Is there any suggestions to have phase change occur?? |
September 1, 2017, 07:32 |
mike
Rep Power: 13 |
Do you have found any solution for that?
May 7, 2018, 13:49 |
fa
Rep Power: 13 |
Hello
Can you please tell me how you used single components and not multi-components in order to use the evaporation model?! I can only use it with multi components. If I do not specify a mixture in the gas star will not run. |
March 21, 2019, 08:12 |
Condensation problem
Have you get the results? becaus I am doing a VOF condensation and It is not working? Any can help me?
condensation, phase change, star ccm+, vof |
Phase change with VOF | shu | OpenFOAM Running, Solving & CFD | 29 | January 14, 2016 14:11 |
Mass Transfer without Phase Change in InterPhaseChangeFoam | Parisa_Khiabani | OpenFOAM Running, Solving & CFD | 5 | May 26, 2015 10:40 |
Mesh sensitivity when using phase change models | BKaus | STAR-CCM+ | 0 | February 28, 2012 21:51 |
thermal phase change question | CFDflying | CFX | 1 | February 18, 2004 05:10 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
