April 3, 2017, 23:51 |
Oscillating of residual for SDR
Jihun,Lee
3D
Steady State Coupled Flow implicit 2nd order Ideal gas RANS AUSM+ FVS K-W SST Using Polyhedral mesh & prism layer Stagnation inlet 10MPa 1500K Pressure Outlet 0MPa Courant Number : 10 No ramp AMG Linear Solver : Low On, Maximum Number of AMG Cycle Monitor 2 Expert Initialization : On Solution Driver : Expert Driver On CCA : On TKE residual is Oscillating Continuity residual : 6.866532e-04 X momentum residual : 6.292211e-04 Y momentum residual : 3.581249e-04 Z momentum residual : 7.172282e-04 Energy residual : 1.076242e-03 TKE residual : 1.066230e-06 SDR residual : 9.982527e-06 All Y+ treatment : Y+ Range 0.05~24 1. If Maximum Number of AMG cycles is 2, can I increase Courant number? 2. Doesn't matter Oscillating of SDR residual for convergence? Is it OK just decrease whether oscillating or not? 3. Can I judge that my simulation reach convergence(steady state), with above residual condition? Thanks in advanced, |
April 5, 2017, 16:02 |
Matt
Rep Power: 18 |
1) I think that more than 5 cycles and you need to reduce your courant, so if you are only seeing 2 I would bump it up a bit. Maybe use a ramp so that it doesn't introduce new issues.
2) You cannot judge convergence solely based on residuals. You need to look at figures of merit as well, which depend on what you are actually modeling. In general, oscillating residuals are not a good thing. However, they are not a huge problem to solve. I would ditch the solution driver, that is probably what is causing it. 3) No, this plot is not enough to gauge convergence. |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
