Reference Frame
Old   March 8, 2017, 16:19
Default Reference Frame
Anna
anna1 is on a distinguished road
Hi!
I´m new to Star CCM+ and I´m struggeling with setting up a Translational Reference Frame. My case is a rising bubble in an endless tank and to reduce computational effort i would like to just simulate a small part of the tank. The Frame should move with the same velocity as the bubble rises, so that the bubble is kept in the middle of the Frame/Part. I tried a "Rotational and Translational Reference Frame" but it does not work as expected (or I did something wrong). Maybe someone has a better idea how to solve the problem?
Many Thanks in advance!
anna1 is offline   Reply With Quote
Old   March 9, 2017, 13:52
me3840 is on a distinguished road
If your bubble is stationary with respect to the tank, you do not need to model the tank's physical motion. From a relative sense, moving the fluid over the bubble is good enough, no?
me3840 is offline   Reply With Quote
Old   March 14, 2017, 05:40
Anna
Thanks for your reply!
Its not really stationary, it starts rising and after a certain time it has a constant velocity. And I don´t want the tank to move physically, I´m looking for a solution that the Frame shows only a small part of the tank and that this frame rises with the bubble. Don´t know if its relevant but I´m using VOF method.
Also I´m unsure with the boundary conditions. The tank should be kind of endless around the bubble and the frame should be slightly larger than the bubble. So the Fluid auround the bubble has to move out of the frame and come in as the flow would be without the frame. I tried Pressure Outlet at all Boundaries with the "extrapolated" Backflow specification but I think it´s not the right condition.
Again many thanks in advance!
Old   March 14, 2017, 10:54
Is the bubble moving through a changing hydrostatic pressure field?
moving reference frame
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 01:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
