February 8, 2017, 19:46 |
Exhaust's air flow in wrong direction
Sandy
Rep Power: 9 |
Hello Star CCM + users,
The air flow at the house exhaust is going inward, however, exhaust type is pressure outlet. Secondly, velocity value at outlet is higher as compared with inlet value. The screenshot is attached. Any suggestions? what could be wrong? In back-flow specifications Direction: Boundary-Normal(this option doesn't specify the direction) Pressure - Environmental Thanks, Sandy |
February 10, 2017, 09:55 |
Rep Power: 24 |
A pressure boundary condition doesn't set the flow direction, it's dependent on the physics of the problem. If there is reversed flow then the pressure of the system must be lower than the outlet pressure.
The velocity at the outlet being higher from your picture is probably fine since there are multiple smaller outlets, so mass is probably still conserved. |
February 15, 2017, 13:19 |
Sandy
Rep Power: 9 |
Thanks me3840!
You are right, I figured out that the volume fraction of air inside the building wasn't defined in initial conditions that is why there was reverse flow! Sandy |
exhaust, inlet, outlet, vector |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
flow Maldistribution in air conditioning | rgd | FLUENT | 0 | July 29, 2013 11:34 |
Wrong direction of flow!!! | hungnguyen1908 | CFX | 5 | July 19, 2013 08:25 |
Flow direction in Buoyant flow | Nav | CFX | 4 | June 30, 2008 00:50 |
