Simulation fails after adding multi-component gas
Old   January 18, 2017, 09:26
Default Simulation fails after adding multi-component gas
Conor Hardiman
ConorH is on a distinguished road
Hi all,
I have an exhaust manifold that I am undertaking flow analysis on. when using a single gas model, the simulation runs without fault.
However, when I change to a multicomponent gas model, the following error message appears:
Error for Segregated Flow:
Bi-Conjugate Gradient Stabilized solver did not converge !
Reversed flow on 378 faces on xxxxxxxxxxxxxxxx
Error: AMG solver diverged.
A floating point exception has occurred: floating point exception [Divide by zero]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide.
Context: star.segregatedflow.SegregatedFlowSolver
Command: RunSimulation
error: Server Error
I have tried refining the mesh, changing from a polyhedral to a tetrahedral, segregated flow and coupled flow with both meshers.
Coupled Flow:
Coupled Energy, Coupled Flow, Coupled Species, Exact Wall Distance, Gradients, Ideal Gas, K-Epsilon Turbulence, Multi-Component Gas, Non-reacting, Realizable K-Epsilon Two-Layer, Reynolds-Averaged Navier-Stokes, Steady, Three Dimensional, Turbulent, Two-Layer All y+ Wall Treatment
Segregated Flow:
Exact Wall Distance, Gradients, Ideal Gas, K-Epsilon Turbulence, Multi-Component Gas, Non-reacting, Realizable K-Epsilon Two-Layer, Reynolds-Averaged Navier-Stokes, Segregated Flow, Segregated Fluid Isothermal, Segregated Species, Steady, Three Dimensional, Turbulent, Two-Layer All y+ Wall Treatment
Thanks
ConorH is offline   Reply With Quote
Old   January 20, 2017, 02:29
me3840 is on a distinguished road
Your case is diverging. Did you have a lot of reversed flow on the single gas model?
me3840 is offline   Reply With Quote
Old   January 20, 2017, 06:48
Conor Hardiman
Early iteration did have a lot of reversed flow but after 200 iterations there was no reversed flow.
Do you propose I change the turbulence model?
Thanks for the reply
Old   January 20, 2017, 10:50
No, I would say you should fix your initial conditions to remove so much reversed flow at the start.
Your BCs do different things when reversed flow occurs, which is probably why your mutli-component one explodes.
You could converge the single-component one and then just switch to mutli-component.
exhaust gas, exhaust manifold, star ccm+
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 17 May 19, 2019 10:45
2 Phase Flow, Gas Jet into Water Simulation Method im_lenny OpenFOAM 3 May 4, 2017 04:20
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 08:55
multi component diffusivity mahut FLUENT 0 October 10, 2007 05:05
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
