Calculating drag coefficient at Re 100 for a sphere
Old   January 11, 2017, 20:27
Default Calculating drag coefficient at Re 100 for a sphere
Harry Hammond
Hah01 is on a distinguished road
I'm attempting to compare the effects of surface dimples i.e a golf ball to a smooth sphere for a university assignment. I thought I would start off validating my domain size and mesh by computing the drag coefficient at a low Reynolds number of 100. However, I can't seem to get a value any where close to the graphs of Cd vs Re that I have found on the web (https://www.grc.nasa.gov/www/k-12/ai...ragsphere.html)
The most common Force Coefficient I am getting is about 0.3, from looking at graphs this should be about 1.0.
Problem definition: Diameter = 0.04267, the sphere is situated 5D from the inlet and 25D from the outlet and at the midpoint of the height and width of the domain, both of which have a length of 10D.
From browsing these forums for similar problems to my own, I see mention of y+ treatment (which I do not fully understand) and for my turbulent sims I have set minimum wall distance to 0.005 which I got from an online calculator.
Many people on this forum have recommended turbulent models. Is this due to laminar models being unable to model the stable vortices behind the sphere at this Reynolds number (100)?
Please could someone recommend physics models and mesh sizes that would fit this problem? Apologies for being vague about my current set up but I have tried loads of different combinations with varying convergence and can't seem to get close.
Hah01 is offline   Reply With Quote
Old   January 12, 2017, 08:10
DL
underrelaxed is on a distinguished road
I realize this doesn't immediately address your question, but can we see a picture of your mesh?
underrelaxed is offline   Reply With Quote
Old   January 12, 2017, 10:05
Harry Hammond
Thanks for replying. I just refined the mesh again, I am going to run another sim and will post the results along with that of the mesh once it is finished.
Old   January 12, 2017, 11:24
Harry Hammond
I cant seem to get my image hosting approved by the mods let me see if this works
Base = 0.02
10 prism layers at 33% of base, layer stretching 1.2
Custom surface mesh on sphere at 10% minimum 25% target
and The volume control block which is set at 80% of base
Old   January 12, 2017, 11:26
Harry Hammond
Looks like I was uploading wrong before. Here is a close up. I'm using a tetrahedral mesher with surface remesher
Old   January 12, 2017, 11:56
Harry Hammond
... and one more which shows the whole domain. Boundary conditions are slip walls for top and bottom, and symmetry planes for side walls. Flow is in positive x direction from inlet to outlet.
Here are the results from the two steady tests I did, blue is Laminar, orange is Turbulent (RANS Spalart-Allmaras standard):
Old   January 12, 2017, 12:25
acalado's Avatar
André
acalado is on a distinguished road
Have you checked what are the parameters used to non-dimensionalize the Force coefficient? (area, reference velocity... )
Sapere aude!
acalado is offline   Reply With Quote
Old   January 13, 2017, 11:33
Harry Hammond
I've doubled checked these and it looks like I've been using the wrong frontal area the whole time! This has improved my results loads I am now getting them close to the 0.7 mark which isn't correct but it is a lot closer, thank you for pointing out my schoolboy error, I was getting way too hooked up on the physics models.
Old   January 17, 2017, 11:22
Ping
ping is on a distinguished road
sad to see someone using a tet mesh - serious star users abandoned these a decade ago
Sent from my iPad using CFD Online Forum mobile app
ping is offline   Reply With Quote
Old   November 12, 2017, 01:51
Qkarl is on a distinguished road
Hi, can I know the outcome of this simulation? what turbulence model did you used and the mesh setting? Thanks in advanced
Qkarl is offline   Reply With Quote
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
is it possible to calculate drag coefficient of sphere anlaytically? S.Rhee Main CFD Forum 0 December 8, 2014 01:32
Too low drag coefficient on a bus Roland R CFX 8 September 21, 2012 06:23
Solidification drag coefficient atulverma FLOW-3D 1 May 14, 2009 10:24
drag coefficient with k-eps model Mark Main CFD Forum 8 April 19, 2004 10:55
