Star CCM+ and Abaqus CoSim
Old   January 11, 2017, 11:41
Question Star CCM+ and Abaqus CoSim
Anon
AAAmodel is on a distinguished road
Hi All,
I am trying to complete the Star CCM+ and Abaqus Mechanical Coupling tutorial I have completed all the steps as outlined in the tutorial guide. I have completed the static section. However when I try to run the dynamic sectio, using abaqus, I get the following error:
Loading the SIMULIA Co-Simulation Engine shared libraries failed.
In order for STAR-CCM+ to automatically locate the libraries, check
the following:
- if the executable name is set to an Abaqus command, the command
must be in the system path (the path cannot be prepended to the
command);
- if specifying the full path to the Abaqus executable, the path
must point to the Abaqus installation directory;
- if standalone co-simulation libraries are to be used in place of
the libraries provided with the Abaqus installation, the
SIMULIA_CSE_LIBPATH environment variable must be set to the
standalone library installation path.
Alternatively, the library path may be explicitly specified in Linux
with the STAR-CCM+ -ldlibpath launch option or in Windows via the system
path.
Command: RunSimulation
error: Server Error
Anyone have any solutions?
Many Thanks
AAAmodel is offline   Reply With Quote
Old   January 20, 2017, 02:34
me3840 is on a distinguished road
It looks like you haven't told STAR-CCM+ where to find Abaqus correctly. Did you check that the path to the executable or the alias for it works, as the error message suggests?
me3840 is offline   Reply With Quote
Old   February 9, 2017, 07:25
Anon
The issue was the version of Abaqus i was using, switched to Abaqus 6.13 from 2016 and it worked no problem
abaqus, co-simulation, mechanical coupling, star ccm, star ccm+
can we model incylinder flows STAR CCM+ farhath Siemens 2 July 8, 2008 16:00
