After 16 iterations giving an error "
Old   January 4, 2017, 19:30
Default After 16 iterations giving an error "
Sandy
Sandy7 is on a distinguished road
Hi Star CCM+ user,
I am trying to find the air flow inside a house model (using stream lines). surface and volume mesh successfully generated and runs fine for first 15 iterations. After 15 iterations, it gives an error " A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause can not be identified. Please refer to the trouble shooting section of the User's Guide. Context star.segregatedflow. SegregatedFlowSolver
I have checked the trouble shooting section but couldn't figure out the reason of this error.
Can some with help!
Sandy7 is offline   Reply With Quote
Old   January 5, 2017, 06:10
Nils Hennig
Fiedde1887 is on a distinguished road
Check your mesh for bad-cells, high skewed-cells, bad Quality-cells. There is a macro at Steve-Portal. Adjust your stopping-criteria and your solver Settings. If the case diverge, that can be a reason.
Fiedde1887 is offline   Reply With Quote
Old   January 5, 2017, 16:15
Kevin
kirrer is on a distinguished road
In addition to the mesh metrics Fiedde mentioned, another common culprit can be the initial conditions, especially if you're applying a pressure somewhere which is significantly different than the initial condition. Try to set initial conditions somewhat close to your final solution.
If that doesn't work, then I recommend you set stopping criteria to 12 or 14 iterations, and review the results at that point in time. Likely you will get some indication of the error - for example, if you have very high velocities or very low densities at some point in space.
Final suggestion, if you are solving air flow in the house, are you using the ideal gas model? That might be adding complexity you don't need. If you want to solve for gravity but you don't expect velocities above 0.3 * c, you can probably get away with a constant density model using the Bousinessq approximation for buoyancy. That would take some instabilities away.
kirrer is offline   Reply With Quote
Old   January 12, 2017, 12:26
acalado's Avatar
André
acalado is on a distinguished road
Indeed, check for high residuals, bad cells, or perhaps the initial conditions can be reset or adjusted to ensure convergence
Sapere aude!
acalado is offline   Reply With Quote
floating point, segregated flow
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
