December 28, 2016, 15:56 |
Error suface not closed
Sandy
Rep Power: 9 |
Hello Star CCM+ user,
I hope all had good Christmas and looking forward for new year! I am working on a house model which has different height for bed, bath and lobby. I have created the house model in solid works and have successfully imported into star CCM+ ( 11.04.012) Objective: the goal for this simulation is to analyze the air flow inside the building. house model and vents: 1. The way I am doing, the house model has been created in solid works and did the 'extrude cut' in order to create gap for vents and exhaust. Next, In Star CCM+, during the surface repair, new rectangle were created (where the gaps were created using extrude cut command in solid works).. and those rectangle renamed as inlets and exhaust. 2. I also realized that every wall has two layers and am trying to delete the one layer for all the walls, is it a good way to go? I am wondering if the above mentioned method is correct or not. I will greatly appreciate any suggestions! Problem facing: 1. In order to get the fine mesh on inlets and outlets, automated mesh option has been used but after creating the automation mesh; a yellow triangle appears in front of automated mesh. Can you please share what does this mean? 2. After the surface meshing; attempt of volume mesh fails error message " Surface is not closed".. Thanks in advance! Sandy Last edited by Sandy7; December 29, 2016 at 12:52. |
house model, solid works, suface, vent |
Closed volume pressure rise with temperature rise | vinayak4399 | FLUENT | 10 | March 11, 2020 09:29 |
closed tank and dynamic mesh | Tobi | OpenFOAM | 6 | March 27, 2018 04:26 |
Modelling an initially closed valve which a fluid opens | siw | CFX | 1 | April 26, 2014 07:32 |
duct modeling with exit closed (v=0) | geetha sri | FLUENT | 0 | July 11, 2012 10:49 |
Problem with forming closed surface set | blip | Main CFD Forum | 0 | June 17, 2005 04:39 |
