December 20, 2016, 04:58 |
Lift Coefficient
Anonymous
Rep Power: 10 |
Hello STAR group,
I am doing an unsteady RANS simulation for a university assignment and I my aim is to calculate the lift and drag coefficients over a delta-type hydrofoil. The force coefficient reports appear to be influenced by an arbitrary area value. For the lift and drag coefficients I was thinking to use the projected area of the hydrofoil (in the cross-stream and stream directions respectively). Would it be more suitable to just use the actual area of the hydrofoil in both cases? Also, I am using symmetry to analyse only half the geometry and I was wondering whether the force coefficients should be eventually doubled to be representative of the full geometry. Many thanks, E |
December 20, 2016, 21:18 |
#2 | |
Rep Power: 25 |
If you have half the force and you use half the reference area, the coefficient will be identical to all of the force and all of the area. So if you use the full area for half the force you need to double. Otherwise no. |
December 21, 2016, 02:28 |
Anonymous
Rep Power: 10 |
Many thanks!
force coefficients, star-ccm+ 10.04, symmetry |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Lift coefficient in Eulerian multiphase model | hennas | FLUENT | 1 | July 4, 2011 17:50 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
Zero Coefficient of Lift Problem | MH | FLUENT | 0 | February 25, 2007 12:48 |
