Rotating Regions in Star CCM+
Old   December 18, 2016, 15:29
Question Rotating Regions in Star CCM+
Henry Skrine
HenryS is on a distinguished road
Hi Guys,
Final year Mechanical Engineering Masters student here with some much needed advice! I've been using Star CCM+ for a year or so now and I have an assignment due in about a month. Its a simple assignment although work beyond the brief in encouraged so I'm looking to go slightly above whats required.
Waffle over:: I'm looking to simulate a bicycle wheel moving forward within a wind tunnel, and provide force reports for both with and without the covers that some racing bikes have. The real assignment is mesh analysis which is pretty straightforward but I'm struggling getting the inital setup to work.
I know how to set up the rotating reference frame and apply it to the relevant region however its setting up the regions I'm struggling with. I've tried importing just the wheel and doing a boolean subtraction from a box created in SCCM+ after meshing the parts however obviously this deletes the wheel region after the boolean subtraction so I have nothing to apply the rotation and translation to. I've tried duplicating a single part, consisting of the wheel subtracted from a box all made in SolidWorks, and then creating one region of just the wheel from the inital part, and another region of the box from the duplicated part. On meshing "computer says no" and I'm getting 'Attempt to access GlobalCommunicator in serial' error warning.
Where am I going wrong? This could be an interface issue as I'm not 100% on that either. Basically I'm asking how to import and set up the geometry and regions for a moving wheel inside a tunnel. If anyone has any words of wisdom I'd be much appreciated. Merry Christmas!
HenryS is offline   Reply With Quote
Old   December 19, 2016, 01:33
me3840 is on a distinguished road
You likely encountered a bug with the error you have there. Are you meshing in parallel or serial? What kind of mesh? What version?
When you are doing the boolean subtract and the wheel is disappearing, I'm assuming then you're doing the subtract in 3D-CAD. There's an option you can tick to keep the tool part which will not delete it.
me3840 is offline   Reply With Quote
Old   December 19, 2016, 19:13
Henry Skrine
Thanks for the reply - I've found making two seperate meshes and applying one to the wheel and one to the wind tunnel has fixed it. Thanks again
movement, rotating region, solid body motion, star ccm+
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
