RANS Turbulence Decay Variation
Old   December 13, 2016, 17:49
Post RANS Turbulence Decay Variation
Kyle
KGRAAT is on a distinguished road
I am a novice Star-CCM+ 10 user who has formal training in ANSYS Fluent. I am completing collaborative research into the free-stream effects on the heat transfer coefficient from a flat plate. The first step is to model and confirm turbulence decay in a rectangular fluid domain of 4x1x1 m.
The domain has been meshed using hexahedral solid elements of size h=0.02m. The front face is a velocity inlet with U=4m/s a turbulence intensity of 10% and an integral length scale of 100mm. The back wall is a pressure outlet and the four remaining walls are slip boundaries.
The k-e RANS model is to be used and confirmed against the power law decay model for grid generated turbulence. I have successfully used ANSYS Fluent to model the decay and have confirmed the results to be correct, but when I use the same parameters and the same model constants in Star-CCM+, I get a result with incorrect turbulence decay (see the graph attached comparing the correct ANSYS Fluent result with the Star-CCM+ result). The data has been extracted using a line probe of 200 points through the centre of the domain.
I have meticulously checked all the models, constants, the mesh etc. against my Fluent studies and have not found a reason why they are different; everything between them is the same except the solution methods. I have read through the Star-CCM manual, but still have been unable to understand why there is a difference.
Any help would be appreciated
Kyle
KGRAAT is offline   Reply With Quote
turbulence decay
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
decay of turbulence intensity littlelz CFX 3 May 16, 2014 17:44
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
