Problem in a simple case
Old   December 8, 2016, 11:33
Default Problem in a simple case
donfrulli is on a distinguished road
Dear all,
I would like to make a simple simulation on air flow in a pipe with a restrictor. The simulation is not converging correctly and I got these errors:
Temperature corrections limited on 615 cells in Region
Minimum Temperature limited to 100 on 924 cells in Region
Turbulent viscosity limited on 13771 cells in Region
My continua settings are: gas, steady, segregated fluid temperature, ideal gas, k-epsilon turbulance. I'm not even sure what are the correct settings.
My experiment looks like this: I put 2 cylinders on each other and I put 4 CDs in between them. I generate a depression from below.
Any ideas what can be the problem?
donfrulli is offline   Reply With Quote
Old   December 9, 2016, 08:32
Nils Hennig
Fiedde1887 is on a distinguished road
Looks like a mesh-issue. Create a theshold for temperature for example and lokate the Region, where your solution have the unrealistic temperature. After that, you can fix your mesh.
Fiedde1887 is offline   Reply With Quote
Old   December 9, 2016, 09:01
For now this indeed looks like a mesh issue because no matter what I did, STAR used trim mesh all the time (even when I set it to poly)
Thanks!
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Simple channel case using cyclicAMI will not converge cbcoutinho OpenFOAM Running, Solving & CFD 3 August 4, 2015 13:28
A simple tube FSI case can't converge stickjohnson OpenFOAM 1 June 23, 2014 22:42
Trouble with simple AMI case Horus OpenFOAM 0 February 26, 2013 10:31
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 07:19
