December 1, 2016, 12:26 |
Problem with star ccm+ optimizer
marco
Rep Power: 10 |
Hi everybody,
Everytime I make an optimate study it returns an error message like this: *ERROR When reading data for "Windows Cluster" of type "Microsoft Cluster Compute Resource" from file "C:\Users\Marco\Desktop\pipeBlockage_a\Definitions .in", error in reading the data for property "jobTemplate". This property was not defined. Run exiting due to an error I have done this example with the tutorial files in the directory of CD adapco. The optimizer ran good initially, but since 2 days every study I do I see this error. Thank you very much. Marco |
December 1, 2016, 15:47 |
Rep Power: 25 |
Did you check what cluster setup you are using optimate with? It's clearly telling you that it has been configured to use a Windows cluster and can't find the configuration for it. Is that your intention? If not disable the Microsoft scheduler option.
December 2, 2016, 07:14 |
marco
Rep Power: 10 |
the problem is that the option is disabled. I don't want to use a Windows cluster but I don't know how to disable this option because the scheduler option is disabled
clusters, error, optimizer, run exiting |
how to open star ccm 6.04 version file in older versions | pritam.edke | Siemens | 2 | June 25, 2012 04:14 |
Urgent star ccm help | itsme_kit | Siemens | 4 | February 2, 2012 18:54 |
Restart Star CCM server? | Apocolapse | STAR-CCM+ | 1 | January 10, 2012 04:56 |
star cd 4.06 parallel problem | whitemelon | Siemens | 3 | October 23, 2008 15:42 |
problem with export ccm from starccm+ | yan | Siemens | 0 | July 22, 2008 06:06 |
