Difficult convergence due to NO-smooth transition
Old   November 11, 2016, 07:37
Post Difficult convergence due to NO-smooth transition
Barcelona
danle96 is on a distinguished road
A part of my problem that I will talk later,
The main question is: How I in Star CCM+could control the transition between Prism Layers and the rest of the mesh
I'm using a 3D mesh polyhedral with the porpoise to mesh front and rear wing of a Formula Student car, for this reason I'm using a superficial treatment for each element searching a y+ results and also a volumetric control that works as a refinement, in my case 1200 iterations isn't enough to fix the TKE under decimal values and I suppose this could be solved by applying a smooth transition, and that's the main thing
danle96 is offline   Reply With Quote
Old   December 19, 2016, 01:37
me3840 is on a distinguished road
I don't really understand what your question is. You want a better transition to the core mesh?
The prism layer mesher has several inputs. In general for external aero, it is preferable to choose the number of layers, total thickness, and first layer thickness. The last layer thickness is a result of those 3 choices. You must iterate through different settings to get you the last layer height you want.
me3840 is offline   Reply With Quote
convergence, formula student, mesh 3d, prism layer, star ccm+
Smooth transition between lines cfdnoob Pointwise & Gridgen 0 July 24, 2014 14:14
Trans. SST Intermittency Factor and Viscosity Ratio eishinsnsayshin FLUENT 3 May 23, 2012 04:02
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
to LANGTRY ROBIN :help, hypersonic transition SST ben akih CFX 0 September 21, 2006 05:59
convergence difficult Jason FLUENT 3 May 20, 2004 13:13
