No heat transfer between solid and fluid regions
Old   October 10, 2016, 00:07
Default No heat transfer between solid and fluid regions
R. Lovelace
lilweasel is on a distinguished road
Hello All,
I have a heat generating sample that is in a double walled cylindrical container. The sample is in the inner cylinder with air. The inner cylinder is inside another cylinder with powder between the two. Water flows over the double walled container.
I have added a total heat of 10,000 W to the sample (this is a very exaggerated number to show that there was heat transfer going between my regions). There are interfaces between all the connecting parts with "conjugate heat transfer" applied. The only boundary conditions applied are mass flow inlet and a pressure outlet.
However, when I run the simulation I get temperature results in the air region due to the heat from the sample but there is no heat transfer from the air to the inner cylinder container.
I've searched on these forums, googled, asked my supervisor, but nothing has helped get this to work. Any advice or suggestions is greatly appreciated.
If there is additional information needed please let me know. Attached is a picture of the type of solution I am getting.
Thank you
lilweasel is offline   Reply With Quote
Old   October 13, 2016, 14:52
me3840 is on a distinguished road
Is your interface actually working? How many faces does the code put in to it? If you highlight the interface, does it have holes in it or not show up at all?
me3840 is offline   Reply With Quote
Old   October 13, 2016, 22:16
R. Lovelace
Thank you for your response.
When I highlight the interface it does show up and there are not any holes in it that I can see. There was an interface created for each side of the cylindrical space, meaning the top, bottom and cylindrical wall all have separate interfaces.
I assume the interface is working, the reason I say this is because I changed the fluid region to a solid region and ran the simulation again and with that there is a temperature gradient shown across all of the regions.
If I change it back to fluid however, I get the issue again. Is there some extra model or buttonI need to turn on to allow for heat transfer between fluid/solid regions?
Old   October 14, 2016, 15:36
Kevin
kirrer is on a distinguished road
It looks like the "air" region is taking the entire gradient, from hot to cold. The contour plot shows blue/green colors near the edges. How long has the simulation run - is it converged? Or is it transient?
If converged, does the air contain any buoyancy (ideal gas or Bousinessq, with gravity simulated)? Is the air laminar or turbulent? I would model the air with gravity + Bousinessq, plus the appropriate turbulence model (check Grashof number, others in the literature, but likely the default K-e model will work).
Finally, give us some clues of the conductivity in materials for inner container, powder, and outer container. Also sizes would be helpful.
Other tip is, have you created a report at the interface which has heat transfer - it's possible to have all 10000W transferred, without a change in the temperature field (at the scale you've shown).
kirrer is offline   Reply With Quote
heat transfer
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
