effect of gravity function
Old   September 29, 2016, 01:16
Default effect of gravity function
sriram
sriram9127 is on a distinguished road
hi every1
Im running a flow through pipe simulation to calculate pressure drop.
I did a simulation with/without gravity function but the results are same.Does gravity affects pressure drop??
How does the gravity function acts in the software.
sriram9127 is offline   Reply With Quote
Old   October 2, 2016, 17:01
me3840 is on a distinguished road
Calculate each component of Bernoulli's equation and compare them for yourself in your case. Does the gravity term matter relative to the others?
https://en.wikipedia.org/wiki/Bernoulli%27s_principle
me3840 is offline   Reply With Quote
Old   October 2, 2016, 20:06
Lane Carasik
lcarasik is on a distinguished road
Originally Posted by sriram9127 View Post
hi every1
If your situation does not include significant enough changes in buoyancy, you are not likely to see any effect on your simulation when using gravity.
Additionally Star-CCM+'s built-in gravity model only accounts for the vertical component of buoyancy effects. Further, you have to be careful when using the k-w family of turbulence models in Star-CCM+ with buoyancy driven or aided flows. It does not account for buoyancy effects in the turbulence equations for that specific family.
lcarasik is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
VOF and gravity effect sirpolar Fluent Multiphase 1 August 3, 2015 08:15
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
