Tet volume mesh generated poorly
Old   September 7, 2016, 14:27
Default Tet volume mesh generated poorly
B.H.
niablis is on a distinguished road
Being quite new to using Star-CCM+, I'm still figuring out how to do even the simplest of tasks. I just generated a simple tetrahedral volume mesh with 10 prism layers. Everything seemed fine and dandy until I created a split plane to look at my volume mesh and it looked as if two meshes were created in the same volume (see the images below). I have Growth Rate enabled, with 1 Optimization cycle and a Quality Threshold of 0.4.
Do I need to run more Optimization Cycles? How do I clean up this mesh?
Thanks in advance!
niablis is offline   Reply With Quote
Old   September 7, 2016, 15:09
B.H.
Oh could it be do to Quality Threshold set to 0.4? I think at first I misread the description to mean the mesher aims for cells above 0.4.
Old   September 8, 2016, 08:49
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hi B.H,
why would you go for Tet-mesh? are you doing some tool bench marking ??
STAR CCM+ is widely known for its robust and memory friendly polyhedral (or dual) mesh. they have better convergence, easier on computer memory and can capture the geometry much better than a tetrahedral mesh.
Regards
ggulgulia is offline   Reply With Quote
Old   September 8, 2016, 13:28
B.H.
I originally chose tets because that is what I used in ICEM. I'll give polyhedral meshing a try. Thanks for the advice!
Old   September 22, 2016, 21:30
me3840 is on a distinguished road
You are viewing a cut through the cells which looks funny. Make a cell surface instead and you will see the whole cell.
me3840 is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
