Forced motion is not following my command
Old   September 7, 2016, 11:16
Default Forced motion is not following my command
Xiaosong Zhang
jsb12136 is on a distinguished road
Hey guys. I am simulating a three-blade vertical axis turbine and it is a forced motion simulation. I input the same rotation motion equations for the 3 blades separately, but the results of torque I got are not right. These results should be in the same pattern with a 120deg delay but they are not. I captured the motion animations and found that the blades are actually not moving as I commanded. What I am really confused is that since it is a forced motion simulation, the blades should moving as the function I input. (I have monitored the function as well and it is absolutely right.) Why does this happen and what is the solution of this situation?
jsb12136 is offline   Reply With Quote
forced motion, motion simulation, star ccm+ v9, vertical axs
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Prescribed mesh motion does not correspond to actual motion rbarrett CFX 8 June 30, 2011 14:22
UDF hook problem in command line mode. Benlong FLUENT 1 November 12, 2007 15:45
tank motion on boat Tim FLUENT 0 May 23, 2007 12:50
large scale mesh motion sb FLUENT 1 April 27, 2007 23:23
