Elliptic Blending Models - Low Re?
Old   August 24, 2016, 06:42
Default Elliptic Blending Models - Low Re?
Res
RESOLO is on a distinguished road
Hi
I am using two Elliptic Blending models, EB RSM and EB k-e, in Star-CCM+ (so far using the "All y+ Wall Treatment").
I assume that both models are Low-Re, but can anyone confirm? For the purposes of writing a report about the models.
Thanks!
RESOLO
RESOLO is offline   Reply With Quote
Old   August 25, 2016, 01:11
Lucky
Yes they are both low-Re models.
Very Off topic: The primary motivation for elliptic blending functions historically is to beef up the near-wall model so they are usually always applied to low-Re models. However, elliptic blending doesn't necessarily imply that the model is a low-Re model. Indeed, one can construct an elliptic blending function even for a high-Re model and I think this should be a direction the community should look towards. Right now we are dealing with near wall treatments assuming the far-field model is correct. However, we know that turbulent viscosity can easily become negative. With elliptic blending, it's much more natural to fix this problem because the flow will be able to see it coming. Basically, rather than compute your turbulent viscosity only locally, introduce a global weight function, the blending function. So who knows, in a few years saying elliptic blending might mean a whole mess of things, in the same way as hybrid RANS-LES now means something almost completely different from what it was originally.
Old   August 25, 2016, 11:39
Res
Interesting. Thank you!
Old   May 30, 2018, 09:53
Nimesh Virani
viranin is on a distinguished road
HI,
I am trying to apply elliptic blending model in STAR-CCM+ for flow inside a convergent nozzel with nozzel exit reynolds number of 28000. since its a low Re-model can I apply it for this problem?
viranin is offline   Reply With Quote
low reynolds number, rans modelling, reynolds stress model, turbulence, wall function
Wrong interface curvature capturing and contact line calculation at low capillary nu Mahmoud_aboukhedr OpenFOAM Running, Solving & CFD 0 April 14, 2015 15:04
Mesh requirements for k-w models Jeremie84 FLUENT 5 June 13, 2014 10:49
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 04:21
yPlusRAS in OF 1.6.x - Low Re Models ivan_cozza OpenFOAM Running, Solving & CFD 0 September 23, 2009 06:27
a low Re number model for impinging jets mahesh prakash Main CFD Forum 14 September 3, 1999 17:40
