August 23, 2016, 05:05 |
volume from importet 3d curve
Fynn
Rep Power: 10 |
I have the following problem: I have a set of 4 curves that are closed, if connected. I want to extrude these curves thus generate an enclosed volume. This works fine if I import one closed curve (namely the four already connected curves), and have star ccm+ interpolate a closed curve. The problem is then that the extruded curve generates only one boundary. But I want to be able to see all 4 boundaries on the extruded body. If I import the 4 curves separately I can't extrude them as a solid but only as surfaces. Then I have the problem that I can't convert the surfaces to a solid (also when I add planes for the lid and bottom). So is there a possibility to tell star ccm+ that my four imported curves are closed before extruding them? Or is there a smart way to define a volume by its surrounding surfaces? Thanks for the help |
August 23, 2016, 05:31 |
Fynn
Rep Power: 10 |
Fixed it!
I include my 4 curves as splines separately. They are all in the same plane (XY) but nevertheless I create a new XY plane sketch and now I can project all 4 curves on my defined plane sketch. That can then be extruded as a solid and I can assign different names to the 4 bounding surfaces defined by my 4 curves. done. Thanks for your help |
geometery, import 3d curve, star ccm+ |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 06:09 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[Commercial meshers] CuBit | t42 | OpenFOAM Meshing & Mesh Conversion | 6 | July 10, 2008 08:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
