August 17, 2016, 23:07 |
Boundary layer tripping
say
Rep Power: 10 |
Hello.
I'm simulating flow around a 6 to 1 prolate spheroid at incidence. I'm trying to trip the boundary layer at x/L=0.2, to compare to experimental results w/ tripping. Has anyone done tripping in Star-CCM+? Would you suggest adding protusions to the geometry, or is there a way to change flow solvers from laminar to turbulent flow at x/L=0.2? Thanks in advance. Sincerely, Seyong. |
August 18, 2016, 10:46 |
Matt
Rep Power: 18 |
You will want to use the turbulence suppression model. Check out the help documentation under User Guide > Modeling Physics > Modeling Transition > Turbulence Suppression Model.
August 18, 2016, 11:06 |
Thanks!
say
Rep Power: 10 |
boundary layer, transition, trip |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
Boundary layer tripping in CFD | Biga | Main CFD Forum | 0 | June 17, 2005 15:30 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
