Best way of keeping solution data?
Old   August 15, 2016, 18:43
Default Best way of keeping solution data?
EDE16 is on a distinguished road
Hi all,
Running some final simulations and like maybe some Im sure I'll think of a scene I want after the sim is run. So looking into using the solution history and/or the auto export solution history options. Im using a file autosave every 250 iterations as I've had some file corruption problems. However, I'm unsure how this may affect the solution history file? Will it only contain the solution data for that given amount of iterations in the sim file or will it continue to hole all iterations once the autosave occurs?
What kind of thing do you all do to access solution data you haven't pre-set to save, ie scenes etc.
EDE16 is offline   Reply With Quote
Old   August 25, 2016, 16:52
Dan
Dan709 is on a distinguished road
Hi EDE16,
I use an autosave at every 500 iterations and a simulation history file that saves specific parameters at every 125 iterations (I am simulating vertical axis wind turbines). The history file seems to take a snapshot of the solution at the specified frequently interval (e.g. this is the pressure scalar field at iteration 250), and then you can go back in time to look at the scalars/vectors you specified at any of those intervals. From my experiences, the autosave feature hasn't effected my history files.
To access the history file (if that's what you meant by solution data), what I usually do is just created a "recorded solution view" by right-clicking the history file in the simulation tree, and then you can drag that solution view into a given scene to display the values.
Hope this helps!
Dan
Dan709 is offline   Reply With Quote
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 08:03
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 01:51
Extracting data along polylines in transient solution blidblid CFX 1 July 27, 2016 03:05
PLOT3D ASCII solution file to MATLAB data file Sandeep Rana Main CFD Forum 4 June 11, 2010 10:48
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
