July 15, 2016, 17:40 |
couple Star-ccm+ with Fortran code?
Rep Power: 10 |
Hi
I am going to do a FSI case. Star-CCM+ is the CFD solver. I have a in-house Fortran code to solve the structural problem. Is there any possible way to couple both to implement FSI case? I notice that Star-CCM+ is able to couple with Abaqus to solve this problem. In my case, I would like the in-house Fortran code replace the role of Abaqus. Thx. |
July 17, 2016, 03:14 |
kevin alun
Rep Power: 15 |
Look in the help under "user defined vertex motion" it is a motion model, so your code will write out the new vertex locations and most likely you will setup reports which write out forces that your code reads. Not sure if this is done within the GUI you might need a java macro to control everything but I know in Java you can run the sccm+ simulation and also execute your code. This is a fun one, enjoy
August 5, 2016, 16:23 |
Falak Sher
Rep Power: 10 |
Use userdefined motion as shown in pic,
But i am not sure in the first two lines what fortran 90 code will be used. |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
how to solve the diverage of high speed centrifugal compressor, CFD code is STAR CCM | layth | STAR-CCM+ | 3 | May 21, 2012 06:48 |
CGNS fortran code compiling with intel visual fortran xe | dokeun | Main CFD Forum | 1 | April 5, 2012 22:01 |
CFD Code with Fortran | murat | Main CFD Forum | 0 | October 11, 2009 18:05 |
A genearl question on STAR CCM | nstar | STAR-CCM+ | 5 | June 24, 2009 10:39 |
