Diffusion Constants Changing with Temperature
Old   July 11, 2016, 16:59
Default Diffusion Constants Changing with Temperature
Wade
wadeellis is on a distinguished road
I am simulating a flow of hot (350 C) helium into room temperature (25 C) air. When defining how the diffusion works, I have not been able to find a way to let the diffusion constant change with temperature. I can define it as a constant, but that is not accurate for the fairly wide temperature range I am using. Does anyone know how to let the constant change?
Thanks in advance.
wadeellis is offline   Reply With Quote
Old   July 12, 2016, 03:18
kevin alun
marmot is on a distinguished road
I guess you are using a Multi-Component Gas, for Molecular Diffusivity the default is Schmidt Number but if you change it to say ComponentMolecularDiffusivities and switch from constant to composite than you can create a field function for each component.
The same with BinaryDiffusionCoefficients, selecting composite gives you the fieldfunction choice.
marmot is offline   Reply With Quote
Old   July 12, 2016, 11:19
Wade
So if I am understanding correctly, once I have selected field function, I then choose Temperature and it will vary the diffusion coefficient with temperature? How does it know what initial value to give for the coefficient?
Old   July 12, 2016, 12:03
kevin alun
No you need to create a new user field function, give it a name, myDiffCoef and say something like 0.2*$Temperature, some function of your choice that is dependent on temperature. The initial value will be whatever your function says, so if your initial temperature is 20C than it will use that value for your coefficient
Old   July 19, 2016, 13:56
Wade
Thank you for that tip. Now that I have defined a field function (I am using the Fuller Schettler Giddings equation to define the diffusion constant), when I try to run the simulation, it tells me the thermal wall function intersection is not found. I am not sure what that means. If it is helpful, the equation I have put in is 0.001*T^1.75 *(1/Ma+1/Mb)^0.5/(va^(1/3) + vb^(1/3))^2 where M is the molar mass of a given constituent and v is related to the cross section of the species in question.
Old   July 20, 2016, 02:37
kevin alun
After initializing the solution are you able to view your field function in a scalar scene? Is it defined properly? Perhaps you were just giving the equation and not the actually field function, for example 0.001*pow($Temperature,1.75)...
Does your simulation run when using a constant diffusion coefficient and the problem occurs when using the field function. Check that each one of the variables in your field function is defined and working properly
Old   August 2, 2016, 17:41
Wade
It is defined properly at each point, however the temperature of the gas is increasing at some points in a nonphysical way. The helium flowing into the air is at 750 K, but the simulation is saying the temperature gets up to over 5000 K. Does defining the diffusion throw off the calculation of temperature?
Also, if I simply use the Schmidt number for the diffusion, does it account for temperature changes? I might be able to get around this whole thing that way.
Old   August 3, 2016, 04:09
kevin alun
I think that is a good idea, start with default Schmidt number and see what kind of answers you get, is the temperature physical how does the He spread in the room, based on these results you would move toward your diffusion coefficient.
If your viscosity and density are a function of temperature it does change the Schmidt number,
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
diffusion effect opposite to convection hasan karabay Siemens 0 December 5, 2006 07:59
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 13:12
CFX4: temperature is changing Miroslav Babic CFX 1 March 2, 2004 19:58
