June 30, 2016, 13:54 |
how to import example models
Haiqin
Rep Power: 10 |
I work with gas-solid fluidized bed simulations, and someone recommended StarCMM+ to me. At this moment, I just want to know whether StarCMM+ works well or not with gas-solid fluidized bed models. So I tried to import example models (there are a lot mentioned in the tutorial) and hoped to test them, but I could not find any. Do anybody know how to import or where to find the example models? Thank you in advance! |
June 30, 2016, 16:42 |
Matt
Rep Power: 18 |
That is all spelled out pretty clearly in the help documentation.
user guide > tutorial guide > ... |
July 1, 2016, 08:04 |
#3 | |
Haiqin
Rep Power: 10 |
By following the tutorial, what I can import directly is just the mesh. So if I want to run the simulation, I still need to finish the following steps, like setting up the physics, creating phases and selecting phase models and so on, by myself, right? |
July 1, 2016, 17:42 |
#4 | |
Rep Power: 24 |
Yes, all the steps should be in the guide. Tutorials are intended to help you learn, I'm not sure what one can learn by just getting a finished solution. |
example models, fluidized beds, import models, starcmm+ |
[Workbench] DesignModeler & mechanical import | Mehdi41 | ANSYS Meshing & Geometry | 9 | August 1, 2016 11:04 |
I developed an FEM toolkit in Java: FuturEye | nkliuyueming | Main CFD Forum | 7 | January 29, 2016 13:28 |
Bad Cd results applying k-ε models to hydrofoil | spk | FLUENT | 1 | December 10, 2011 08:27 |
Import transient cfx-results for static structural analysis in Ansys WB 13 | Colt Seavers | ANSYS | 1 | August 11, 2011 06:01 |
Import Maya models into gambit. | Havocwreaker | FLUENT | 0 | November 27, 2007 07:44 |
