Air compressibility in Flat plate slamming simulatiion |
June 10, 2016, 02:59 |
Rep Power: 12 |
Hi All
I am trying to add the air compressibility to flat plate slamming simulation, But I have a few knowledge about this, I am not sure should I use idea gas or user defined EOS, also I am not sure which energy model should be chosen for the Adiabatic compression isentropic process. anybody have the knowledge about this? Many Thanks Jason |
June 28, 2016, 02:01 |
Rep Power: 25 |
Well, you need to use your knowledge of the physics problem to determine this. Is it appropriate to treat the air as an ideal gas with your physics? If so, select ideal gas. If not, you need to figure out what equation of state to use.
air compressibility, flat plate slamming |
Flow over a flat plate as an immersed solid | hamed.majeed | CFX | 4 | September 8, 2016 15:40 |
DNS for Impinging Jet on a Flat Plate | Chandra Shekhar | Main CFD Forum | 3 | January 18, 2010 06:03 |
Conjugate heat transfer for film-cooled flat plate | Michele | FLUENT | 0 | July 3, 2006 09:42 |
Free convection flow over vertical flat plate | Polly | Main CFD Forum | 1 | February 11, 2003 14:25 |
Free convection flow over vertical flat plate | Polly | CFX | 0 | February 11, 2003 03:51 |
