Floating point exception in combustion models
Old   June 1, 2016, 05:54
Question Floating point exception in combustion models
Bücherknopf is on a distinguished road
I'm relatively new to CCM+ an I hope that somebody can help me with the follwoing problem.
I'm trying to simulate a methane combustion in a pre-chamber. I have a mass flow inlet at the top and a pressure outlet at the bottom. Both boundaries are regulated by one table(time) each. When I'm doing the simulation without a combustion("non-reacting"selected in the Physics Models) there is no problem and the simulation is running.
As soon as I change the Physics Models to "reacting" I'm getting several problems:
-if I want to simulate with "coupled Flow" the simulation doesn't start and I get following error: Unable to initialize alls solvers after 10 passes.
-So I switched to "segregated Flow" an try to run an premixed coherent flame model combustion. In this case the simulation seems not to converge and after a few iterations I get the error: A floating point exception ...
-If I try it with a "non-premixed combustion" (because here I can choose the species on the boundaries and the initial conditions) I get the same error: A floating point....
Has anybody suggestions what I can do here? I'm glad about every suggestion
Regards
Bücherknopf is offline   Reply With Quote
combustion, floating point
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
