VOF coupled with DEM
Old   May 30, 2016, 06:25
Default VOF coupled with DEM
roberto
robro92 is on a distinguished road
Dear all,
I'm working on my master thesis on a CFD application of a curtain particle receiver for CSP technology, so we have solid particles which exit from a hopper and receive solar radiation interacting also with air (entrainment). After the implementation of pure lagrangian multiphase/DEM model, we want to compare the results with a VOF coupled with DEM, so a Eulerian (for the air the VOF) -Lagrangian (particle tracking with DEM). In practice we would treat the particle like a sort of fluid.
Is it possible to use both models simultaneously? Which countermeasures should be applied?
I attach the selected models for my simulation (to start i assume no radiation, only flow field).
Best regards
robro92 is offline   Reply With Quote
Old   March 1, 2023, 10:32
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Hi
Have you found the answer to this question?
Best Wishes,
Mahmoud
Mahmoud Abbaszadeh is offline   Reply With Quote
cfd, dem, particle, vof
Two-Way coupled DEM with heat transfer - Which is good?:+ LIGGHTS/OpenFOAM/CFDEM/<??> yesaswi92 Main CFD Forum 1 November 27, 2023 05:49
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Eulerian–Eulerian coupled with VOF jamalf64 FLUENT 13 May 23, 2016 09:08
Diffrence between VOF alone and VOF coupled Level 7 ?? Valeck Fluent Multiphase 10 August 19, 2013 05:22
the initialization of the coupled level set method and vof model in FLUENT 13.0 dutliang FLUENT 3 December 13, 2011 22:28
