Heat flux distribution for transitional flow not matching laminar values |
May 25, 2016, 08:02 |
Rep Power: 10 |
Hi!
I am simulating a hemisphere-cylindrical body at high Mach numbers vor various altitudes and wall temperatures with the gamma Re-theta model to see the transition process. For a given flight point I launched a laminar case and a transitional case, when I plot the skin friction along the body my transitional values match the laminar ones, in the laminar part of the flow (up to transition)... which is not the case (at least near the stagnation point) for the heat flux distribution (see attached pictures) Anyone has an idea where it might come from? Cf.jpg Flux.jpg |
heat flux, laminar flow, skin friction coefficient, transition flow |
Channel flow with heat flux | Cara Gao | OpenFOAM Pre-Processing | 4 | September 28, 2014 18:52 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
heat transfer with laminar flow | David_010 | OpenFOAM | 10 | November 16, 2012 16:05 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
a laminar flow and heat transfer problem | majestywzh | FLUENT | 1 | April 16, 2003 03:39 |
