Working with an energymodel
Old   May 25, 2016, 06:56
Default Working with an energymodel
Nils
Deranda is on a distinguished road
I start working with an energymodel for my simulation right now, just to get a boundary temperature for the bai-gosman collision model.
However, if I use the regular molecular weight of air (28.96 g/mol) the calculated density is 0.9 kg/m³. but it should be 8.238 kg/m³ (at 8.5bar and 86°C)
If I calculate the density with the thermodynamic equation of state
p*v=m*R*T
-> density = p/(T*R_L/M)
The calculated density is 8.238 kg/m³. Now I changed the molecular wight of air until the density fits. The result is 246 g/mol. To me it looks like the universal gas constant is different to 8.31 J/(mol*K)
Would be nice if you share your experiences with me
best regards
Deranda is offline   Reply With Quote
Old   May 25, 2016, 07:11
kevin alun
marmot is on a distinguished road
Perhaps before changing MW, when you say density is that the cell-center value, using cell-center temperature, but perhaps you are looking at wall temperature and calculating a density based on this. Just an idea to check this,
marmot is offline   Reply With Quote
Old   May 25, 2016, 11:02
Nils
well I've chosen 359.15K (86°C) as the inlet, outlet, boundary and initial temperature
Old   May 25, 2016, 12:25
kevin alun
OK, did you set your reference pressure to 8.5bar and initialize with 0 static pressure, or did you initialize the pressure to be at 8.5bar, leaving the reference pressure at default, this could also be a reason,
Is the subsetMotionSolver working in parallel? Arnoldinho OpenFOAM Running, Solving & CFD 7 April 27, 2016 05:38
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working Leech OpenFOAM Installation 8 August 10, 2014 21:42
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 03:01
Working directory mgonzalo FLUENT 1 November 11, 2011 11:05
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 23:33
