Initial Center of Mass
Old   May 20, 2016, 21:41
Default Initial Center of Mass
rahul
king_411 is on a distinguished road
This is my first time on the forums, and I am extremely new to CFD, so please bear with me if I ask simplistic questions, or do not understand the terminology.
I am finding the rotation rate of a VAWT, and if anyone has a better way for preparing the geometries, physics values etc., I am all ears.
The simulation consists of a rotating body, and a an embedding cube (used in the same way as "Marine Resistance Prediction: KCS Hull with a Rudder"). I have DFBI Embedded rotation motion on the rotating body, and have inputted the rotating body as a 6-DOF body. The rotating body has a body motion of One-DOF Rotating Motion around the z-axis. The initial center of mass is the origin (laboratory coordinate system). When the simulation is run, the following error message pops up:
Rigid Body "Body 1" has no embedding interface. Please check initial position of center of mass!
Command: RunSimulation
error: Server Error
I have found a forum that deals with the same issue: http://www.cfd-online.com/Forums/sta...ping-grid.html . However, the solution did not help in my case.
I am quite sure the initial center of mass is the origin of the rotating body, so perhaps the problem is converting between laboratory and local coordinate systems (I do not know how to convert) ???
All help will be appreciated. Thx.
king_411 is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 20:31
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
