Problem in visualisation of constrained streamlines |
May 13, 2016, 11:49 |
Rep Power: 10 |
Hi everyone,
I'm trying to do something very simple as visualizing streamlines on different planes in a simulation with Starccm+11.02.009, however I'm able to visualise the streamlines only on some planes and not others and I don't understand why. Has someone has had the same problem ? To create my streamlines on a cut plane I create a constrained streamlines with for the input parts and seed parts the same cut plane. It works wells for the 2 planes passing through the origin axes but not for the other planes (as for the Plane-Y1 in the picture). I have tried in the other planes to change the vector field, and modified the the option in the constrained streamlines but I didn't find any solution. I thank you in advance for your help |
May 17, 2016, 10:36 |
Rep Power: 10 |
Find out that it works well by copying the derived parts that are working and after modifying these parts. However still no clue why it doesn't work directly when go via the Derived part->new part->Constrained streamline.
constrained, strarccm, streamlines |
Visualisation problem pls help! | Juan | FLUENT | 3 | July 8, 2012 13:01 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
visualisation of limiting streamlines | babi | CFX | 0 | March 8, 2002 03:07 |
