pressure outlet on star ccm+ : water heater tank
Old   May 12, 2016, 05:01
Default pressure outlet on star ccm+ : water heater tank
clara lepri
ensiame is on a distinguished road
hello,
we are french students in an engineering school and we are working on a school project with Star ccm+. Our subject is the visualisation of the temperature stratification in a water-heater tank.
We created the geometry with a "valve" in the bottom which is a little hole in a corner and we put the pressure outlet condition on. indeed, our water-heater is a closed environnement so we need this valve to avoid issues with temperature and pressure increase. But we don't know how to parameter it.
We used these parameters : steady, laminar, gravity, 2D, gradient, polynomial density, segregated fluid temperature, segregated flow, liquid.
we never used the pressure outlet option with our teachers so we don't even know if we have to chose "target mass flow", "pressure jump" ...
we want to simulate a leak (whit the valve) when the pressure is greater than 3bar. The heat comes from an electrical resistance in the bottom.
thanks you for your answers
ensiame is offline   Reply With Quote
Old   May 12, 2016, 07:44
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by ensiame View Post
hello,
Just specity the pressure. As name suggest "target mass flow" option will add pressure to specified pressure to match the targetted mass flow. Pressure jump also adds pressure jump.
If you use default settings then you just specify pressure and dont touch other things.
arjun is offline   Reply With Quote
Old   September 12, 2022, 08:15
Marc Ricart
cramr5 is on a distinguished road
Hello, how did you do this? I am trying a similar thing with a valve that should release when inner pressure is >0.1 bar.
I tried with a Pressure Outlet with a Pressure of 0.1bar but the simulation diverges. Not sure how to model that
Any idea?
cramr5 is offline   Reply With Quote
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
Using pressure outlet BC Shreyansh FLUENT 0 November 5, 2010 15:57
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
