How to set correctly the temperature range?
Old   May 2, 2016, 12:08
Question How to set correctly the temperature range?
Francesca Guardavaccaro
starlight is on a distinguished road
Hello everyone,
I'm new at working with Eulerian Multiphase and Segregated Fluid Temperature models and I'm just trying to make the new physics work, so I don't have real data about temperature, density or dynamic viscosity yet.
I've noticed that changing the temperature range obviously affects the results and I was wondering if there's a correct way to select the temperature range!
Thanks for your help and time!
starlight is offline   Reply With Quote
Old   June 28, 2016, 02:27
me3840 is on a distinguished road
I'm not sure what you're asking. How you should set the temperature range on your material property data?
The correct way to set the range would be to get the material property data. Anything else is just guessing.
me3840 is offline   Reply With Quote
Old   June 28, 2016, 02:56
kevin alun
marmot is on a distinguished road
I think we discussed this issue before
marmot is offline   Reply With Quote
eulerian multiphase, polynoimial in t, segregated flow, temperature range
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
How to set heat transfer coefficient and wall temperature jpina FLUENT 1 March 21, 2016 09:47
How to set a initial temperature and constant heat flux at same BC's?? Jane FLUENT 4 October 25, 2015 13:01
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
set temperature on subdomain, in transient mode nicolas CFX 0 August 16, 2006 07:42
