Lift and Drag Force on a planing surface (hull)
Old   April 28, 2016, 11:53
Question Lift and Drag Force on a planing surface (hull)
Jochen
josch is on a distinguished road
Hey guys,
Im working on a simulation to calculate lift- and drag forces on simple planing surface.
dimensions: 1.691m (lenght) x 0.49m (beam) x approx. 0.06m with a small deadrise angle.
draft: 0.04m
trim: -2 deg
velocity: 4 m/s
Therfore I worked with the EHP add on form Star CCM+. That includes VOF between air und water and the DFBI motion for the planing surface. At what I already disabled heave and pitch motion to shorten the calculation time. The mesh looks actually really good ....as far as i am concerned :-)
Despite everything I still get very illogical results. A negative lift force of -5 N and a total drag force of 8 N. I already check the directions of the force reports. Furthermore Im not sure if it is normal for a simulation like this that the residuals are oscillating (as you can see in the pic.)
Im pleased about very help or hint I can get from you. I could also send you the sim. file or other information if that helps
josch is offline   Reply With Quote
Old   April 28, 2016, 14:47
Matt
fluid23 is on a distinguished road
I assume since you are using DFBI that this is an implicit unsteady analysis, no?
It is totally normal for an unsteady analysis to show oscillations in the residuals. This is a byproduct of how each time step is resolved before moving on to the next instant in time.
As for your results, there are any number of issues that could cause this. Unfortunately, you don't give enough info to tell. However, given your residual plot I would start with your initialization and stopping criteria. I would initialize your unsteady analysis by first running a steady state analysis. This will get you a better starting point than default initialization on an unsteady analysis. Then I would also consider loosening your inner iteration stopping criteria. It looks like you kept the default of 5 iterations per time step. This is almost never enough. I would start out with something more on the order of 100 or 200 then reduce it once you see how well your residuals converge. Right now it would appear that you don't even give them a chance to drop so you could very easily be getting bad results just from that. As the solution progresses, you can further reduce the number of inner iterations as appropriate. Just monitor your plot and when they either get below some theshold (my typical goal 0.001) or they flatten out simply adjust based on how many iterations it took to get there. Now, if your residuals are flattening out at a high value then you probably need to think about also adjusting your time step. Rarely will the default value of 0.001 seconds be the best choice.
fluid23 is offline   Reply With Quote
Old   May 19, 2016, 18:42
Jochen
Hey thanks for these hints I tried to adapted the sim. a bit like you said it. But even with 100 inner iterations (time step of 0.002) the residuals look strange .....as a comparison I changed the inner iterations back to 10 (circled in red in the pic). Also it is strange that lift and drag forces are so small.....
The mesh should be ok with 1.6 mio cells and lots of volumen and surface refinement. Also I unabled the pitch so that the surfboard has only 1 DOF (heave in z-axis)
So how can I adapte the timestep? and by which criteria?
Im thankful for any help
Old   May 19, 2016, 18:51
Jochen
Here are few more pics
Old   May 29, 2016, 12:24
ahmet avci
avciahm is on a distinguished road
how can i get "EHP" tool ?
Originally Posted by josch View Post
Hey guys,
draft: 0.04m
trim: -2 deg
velocity: 4 m/s
Attachment 47053
Attachment 47054
Attachment 47055
avciahm is offline   Reply With Quote
drag, ehp, hydrodynamic forces, lift, planing hull
How to calculate lift, drag and lift distribution in Star CCM+? israelcasillas94 STAR-CCM+ 4 November 6, 2020 09:35
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
drag force and lift force? davoodsae CFX 1 October 4, 2010 19:02
CoL, Lift force, CoD, Drag Force Echidna CFX 3 June 18, 2010 06:59
Lift and drag force Arti Main CFD Forum 0 April 23, 2009 23:46
