Multiphase Flow Properties varying with temperature!
Old   April 28, 2016, 08:42
Default Multiphase Flow Properties varying with temperature!
Francesca Guardavaccaro
starlight is on a distinguished road
Hello everyone and thank you in advance for your help!
I have to simulate an internal multiphase flow with properties like density, dynamic viscosity, etc. varying with temperature.
So far it has been performed an isothermal simulation.
I would like to understand which is the best model setup and how to set/manipulate for example the polynomial density.
Unfortunately I'm not an expert and this post may be really confusing, sorry about that.
Anyone could help?! Star CCM+ manual is no longer helping me.
starlight is offline   Reply With Quote
Old   May 9, 2016, 17:12
kevin alun
marmot is on a distinguished road
I like to use the User Defined EOS, I create a table, simple csv file and import that below in tools, csv file looks like this T (K), rho (kg/m**3), mu (Pa-s), k (W/m2-K)
now for example density, select method Table(T)
set T and rho
I find working with tables easier than coming up with field functions or polynomials, its not slower in terms of CPU time
marmot is offline   Reply With Quote
Old   May 10, 2016, 11:58
Thank you very much for your reply! I'm trying working with user-defined EOS but I'm having some issues with calculation convergence!
Old   May 11, 2016, 06:24
kevin alun
You might need to limit the min and max Temperature in the reference conditions. Than make sure your temperature dependent tables cover the temperature range you limit.
You might want to do things like gas phase is constant density, liquid phase is temperature dependent, does it converge, than try both.
Make sure your temp data is smooth, no large jumps and such
remember multiphase convergence is an art form, have fun
eulerian multiphase model, multiphase temperature
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Flow with periodic temperature Florian31 STAR-CCM+ 0 May 28, 2015 05:05
Difference in flow distribution of single phase and multiphase analysis shivasluzz CFX 0 April 22, 2015 23:54
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
error message cuteapathy CFX 14 March 20, 2012 07:45
