how to set exit pressure correctly?
Old   April 26, 2016, 14:54
Default how to set exit pressure correctly?
sulaiman
sms1424 is on a distinguished road
Hey Guys,
I'm simulating turbulent flow inside square duct, with known inlet velocity and exit pressure. The value for exit pressure is 15 pa gauge.
I'm not sure how to set this 15 pa in star ccm+, I just used the outlet region and specify the pressure there to be 15 pa. Is that right? do I have to enter the gauge pressure or absolute pressure in this case?
Also, one more thing, If I want to plot the pressure along the duct, do I have to use " pressure" or "static pressure"? and is the difference between them?
Any input from you is very helpful!
Thanks!
sms1424 is offline   Reply With Quote
Old   April 26, 2016, 16:49
Matt
fluid23 is on a distinguished road
The pressure you specify in the outlet boundary will be gauge pressure referenced to whatever value you enter into the reference pressure under continua>physics>reference values. If you know your exit pressure in guage, just enter it and make sure your reference pressure is set to whatever ambient pressure is appropriate.
I believe the difference between pressure and static pressure involves gravity. Static pressure is a spherical tensor acting on the fluid that is independent on height. Pressure will be static pressure plus piezometric head. If you don't have gravity physics model selected they will be the same. For air, the difference will be fairly negligible but if you have a dense fluid like water then it could make a noticeable difference.
fluid23 is offline   Reply With Quote
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
What BCs to set in Fluent when I know only the static pressure at Inlet and outlet? nikesh FLUENT 0 January 30, 2015 00:32
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 21:04
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
