April 13, 2016, 12:28 |
automation of simulations
chawki tahri
Rep Power: 10 |
hi guys
i am trying, in my simulation, to visualise the variation of the volume fraction. I will change the volume fraction in the inlet, and see what happens in the outlet. It is not a good idea to do it manually, so that i created my macro. What i want to do after is to create a file(.batch) with matlab, that automate all the simulations. Can anyone here help me. Thank you for your future answers. |
April 13, 2016, 20:42 |
Chaotic Water
Rep Power: 18 |
You may try Optimate (see the corresponding chapter of the Manual) - the Design Sweeps option, in which you set parameters you want to vary (geometric and/or physical), range and step.
Or you may try in the way it is described in tutorial "Moving Reference Frames: Marine Propeller in Open Water": parameters are changed each X iterations, which i would not recommend because the amount of iterations per simulation is fixed independent of the convergence. |
Unphysical Results of Low-Re Airfoil Simulations | ericthefatguy | SU2 | 2 | February 2, 2015 06:07 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 02:31 |
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations | maddalena | OpenFOAM | 2 | July 13, 2011 09:55 |
Timestepping in two - phase Simulations using RSM | challenger85 | CFX | 0 | January 4, 2010 06:00 |
URANS and Transient Simulations | bob | Main CFD Forum | 0 | October 1, 2003 04:54 |
