Facing a floating point error when reducing time step in a unsteady simulation
Old   April 6, 2016, 13:55
Unhappy floating point error when reducing time step in an unsteady simulation
lailai
withwolf is on a distinguished road
Hi, everyone,
I'm running a unsteady simulation of a valve closure process using DFBI and overset mesh. The simulation runs well with time step 2ms, 1ms, 0.5ms. But an error occurs when I tried time step 0.25ms.
The error message is "A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide.
Context: star.keturb.KeTurbSolver
Command: RunSimulation
error: Server Error"
I tried increase the maximum inner iteration, but didn't work.
I am using implicit unsteady, 2nd-order temporal discretization, K-E turbulence model, reliazable K-E two layer. The mesh continua is trimmed mesher and prism layer.
Can anyone give some explanation or solutions?   Thank you.
withwolf is offline   Reply With Quote
Old   April 11, 2016, 22:09
Unhappy
lailai
Can any one give some suggestions?
I'm at my wits' end.
Old   April 18, 2016, 03:06
tuvia milshtein
sarahtuvia is on a distinguished road
Try to decrease the under relaxation factor of the KE turbulence in solvers
sarahtuvia is offline   Reply With Quote
Old   April 23, 2016, 16:01
lailai
Thank you for your reply.
I've already tried that. I decreased the KE turbulence relaxation factor from defaulted 0.8 to 0.2. But got the same error again.
Old   November 9, 2018, 14:40
nakkasujith@gmail.com is on a distinguished road
Hey, I am getting same error. Did you get any answer ?
nakkasujith@gmail.com is offline   Reply With Quote
Old   November 10, 2018, 18:11
Maddin is on a distinguished road
Stop the simulation before the error came up.
Make a Threshold for some physical values and then look for the too high values...
Then decide is it a mesh issue or a iteration/time step issue.
Maddin is offline   Reply With Quote
Old   November 14, 2018, 17:33
acalado's Avatar
André
acalado is on a distinguished road
Yes, it might be a mesh issue. You can try plotting different residuals to see where the highest are or some unrealistic values and pin point which cells might need to be fixed.
Sapere aude!
acalado is offline   Reply With Quote
Old   November 14, 2018, 20:38
Yongbo Chen
Yongbo is on a distinguished road
Hi, wolf
I use starccm+ to solve shiphydrodynamics. I found the 2nd order sometimes cannot work. please try 1first-order temporal discretization.
Yongbo
Yongbo is offline   Reply With Quote
floating point exception, time step, unsteady simulation
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
