March 20, 2016, 15:16 |
Geometry representation bug
André
Rep Power: 10 |
Greetings.
I'm having trouble defining a cylinder for some operations which crosses my foam. By using the 'edit part in current scene' I am able to locate the cylinder precisely where I want it (see pic) but after I hit 'Apply' I can't see the cylinder. I've checked the parts included in the Geometry scene, but a strange thing happens. When I hit Apply Representation -> Geometry: I see only the cylinder. When I choose Apply Rep -> Import I can only see the foam. The foam is defined as a Region (imported this way), and the cylinder is a Region created from a Part, I'm guessing this may be the issue. Thanks in advance for any help!
Sapere aude! |
March 21, 2016, 17:02 |
André
Rep Power: 10 |
Problem fixed.
Sapere aude! |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 03:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 14:02 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 04:08 |
[General] Representation "Surface" is displayed correctly, but Representation "Outline" is not | macfly | ParaView | 4 | March 22, 2014 10:54 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 14:49 |
