CHT problem
Old   March 17, 2016, 10:09
Default CHT problem
mobiuspizza is on a distinguished road
Sorry I am new to CFD I hope what I ask makes sense
I wanted to model natural convection for a thin plate object suspended in a fluid in an enclosed volume. The solid has a higher initial temperature.
I have imprinted the fluid and the object and created a solid-fluid interface. The mesh is conformal with percentages at 98% for master and slave.
I am confused as to what to put in at the Region\Solid\boundary\wall-touching-fluid
physical conditions\thermal specification, am I suppose to put Convective?
What about the Region\Fluid\boundary\wall-touching-solid
physical conditions\thermal specification ? It is defaulted to adiabatic.
When I set both to adiabatic, the fluid never moves and there is no convention (plotting velocity vectors show up as empty). I guess that is modelling pure conduction if I do that.
Should I put convective then if so which boundary? Fluid side or solid side? If I do that it asks for the heat transfer coefficient. Surely that's the output of the simulation, I wouldn't have a clue what it is suppose to be.
Many thanks
mobiuspizza is offline   Reply With Quote
Old   March 21, 2016, 23:25
LeeTao
LeeTao is on a distinguished road
Hello, mobiuspizza
I think I can understand what you mean.
If you want to simulate convection, use the ideal gas model with Energy model, then the fluid density will change with temperature and pressure, then you can see the convection flow.
Here is my suggestion.
Leetao
LeeTao is offline   Reply With Quote
Old   March 22, 2016, 00:23
kris
kguntur is on a distinguished road
Yes. You need to model the gas as anything other than constant density. Also, dont forget to select gravity as well.
kguntur is offline   Reply With Quote
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
tips to speedup the convergence of CHT problem with gravity derisala FLUENT 1 February 24, 2011 03:28
CHT strange problem MatejK CFX 3 September 1, 2005 06:32
CHT problem sch CFX 2 July 11, 2003 11:32
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
