Mass flow across a line - tube bundle
Old   March 11, 2016, 10:05
Default Mass flow across a line - tube bundle
Res
RESOLO is on a distinguished road
I am trying to find the bulk velocity of fluid through a tube bundle. To do this I want to start by taking a creating a line probe perpendicular to the flow, then for each cell along this line taking the cell height x velocity through cell (then averaging across line later).
Can anyone help? Firstly to position the line probe in such a way that each point is in the cell centre, and then to plot the corresponding velocity across this line.
I have to do this for three different coarse meshes.
RESOLO is offline   Reply With Quote
Old   March 15, 2016, 15:14
Matt
fluid23 is on a distinguished road
First, unless you specify otherwise any probe point in a cell will return the cell centered value.
Second, I think there is probably an easier way to get this using derived parts and mass flow averaged velocity report.
fluid23 is offline   Reply With Quote
bulk inlet velocity, line probe, mass flow rate
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Mass flow discrepancy BenMUC CFX 3 May 2, 2014 04:29
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
